Quick and easy mods or tweaks??
Old Feb 28, 2010 | 01:41 AM
tinkerinman's Avatar
tinkerinman
Talking Quick and easy mods or tweaks??
Chime in... I know yall know...
Old Feb 28, 2010 | 01:44 AM
jasonw's Avatar
jasonw
Site Moderator
Not to be that guy that tells you to do a search and doesn't help you, but...
Did you try doing a search?
14x3 air cleaner assembly comes to mind, synthetic fluids, Fastman TB (not cheap, but definitely quick and easy), etc. Others will pipe up with ones I missed.
Old Feb 28, 2010 | 01:48 AM
Gerehead8's Avatar
Gerehead8
headers, poor mans TB, modded kegger
Old Feb 28, 2010 | 01:49 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Keep your foot out of the gas.
Old Feb 28, 2010 | 01:51 AM
tinkerinman
No. I did not do a search... I just want honest opinions from people... Also may be things there are no threads for....
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
+1 haha
CPTAFW163's Avatar
CPTAFW163
check out my sig. I don't have the truck, but most of the parts. The PCM will not work for a 94, and the headers are iffy for a fit. BUT, if you want the ignition setup I can part with that for 100 bucks. It comes ready to install, and I spliced quick connects to it so you can return to stock specs for emissions OR if the box ever stops working. You get the MSD 6AL box, coil, and all wiring. I can't install it on my truck because I bought a 2001 and it still has the extended service warranty thru 2012.
--Dan
Old Feb 28, 2010 | 01:55 AM
CPTAFW163's Avatar
CPTAFW163
BTW, the injectors listed are good for 5.2L trucks. THe only thing is that you will need the fastman O2 sim...I forgot to take that off my truck before I junked it. 75 bucks Here:
http://www.thefastman.com/02Simms.asp
Only for the after cat sensor. The injectors come with the new connectors and attached to a fuel rail. 385 brand new. These only have 4K miles on them and I will part with them for 100.
Old Feb 28, 2010 | 02:07 AM
tinkerinman
I hate emissions tests!!!!
Old Feb 28, 2010 | 02:14 AM
halfamil's Avatar
halfamil
If it ain't broke, don't fix it!!!
