2wd A ARMS
Old Feb 28, 2010 | 09:54 AM
pimpinphil's Avatar
pimpinphil
Default 2wd A ARMS
hi,
i was going to replace my front suspension components,the truck has around 226xxx miles now,and my father had replaced a ball joint before when he owened it. however for what ever reason,he welded the ball joint into the a arm. does anyone know where i can buy aftermarket tubular a arms? or new a arms? thanks in advanced.
its a 96 1500 2 wd 5.2 5 speed. ext. cab short bed. thanks again.
Old Feb 28, 2010 | 01:40 PM
RM_Indy's Avatar
RM_Indy
If he just tacked it use a dremel with cutoff wheel & be carefull.
If he went nuts your looking at getting arms from the wreckers. Only tubular arms available are for lowering or bags. If you dont mind dropping the stance these links may help
http://www.stylintrucks.com/Articles...y/Article.aspx
http://www.airbagit.com/Lowering-Con...rms-s/1845.htm
