let me ask you this. what sensor sends the signal to all my digital overhead gas keeper tracker thingy.....lol......???....bc that goes off my speed and mileage....hence whay its all efffed up right now.
Im not sure on that one....i say replace the axle sensor, and that SHOULD give you the speedo back....(It did in the 03 Dakota i worked on, and it has the same axle).
its only like 28 bucks (27. and change with tax) So its not to bad...im 99.999% sure that will fix the speedo, but the OD im not sure....you never know maybe both sensors crapped out at the same time.
so when i remove the sensor from the tailshaft to replace that one.....is tranny fluid going to gush out or will i have time to compare the new and old sensor?
