speed sensor
Old Feb 28, 2010 | 06:09 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
no i havent taken it to have a code pulled. i think i may do that tomm....being layed off does have its advantages i guess....i dont really care that my speedo isnt working bc i havent "put" a mile on my truck in 5000 miles its just annoying as **** that the OD is effed up and my dgital mileage thing on my heads up display is all wrong and confused
Old Feb 28, 2010 | 08:11 PM
meanwhitemopar's Avatar
meanwhitemopar
im having problems with my overdrive, but im taking care of this whole thing tomorrw... im doing everything from detent cable adjustments, to the linkage for the selector, to the speed sensor, and a tune up, plugs and wires here i come...
checking vac lines, just about everything tomorrow
Old Feb 28, 2010 | 08:14 PM
xxxcowxboyxxx
yeah i know you have been having the most horrible luck with your trans lately. i hope you get everything figured out.
Old Feb 28, 2010 | 08:18 PM
meanwhitemopar
yea i should.... i mean, i know my truck better then they do... so im going to go hook the truck up my way this time... and have it done right
Old Feb 28, 2010 | 08:26 PM
xxxcowxboyxxx
yeah. i hope there aint anythign fukked in your trans, and if there is...make sure you grenade it doin neutral drops or something to get a warranty replacemnt
Old Feb 28, 2010 | 08:35 PM
95RAM360's Avatar
95RAM360
id just replace the one on tailshaft just for the hell of it (if when you pull the codes, it doesnt pull this sensors code), and do the one on the axle....thats my honest opinion....
I thought 98 and up didnt have the sensor on the tailshaft
After thinking about it, i would say the one on axle is the one that does the most work....if the sensor at the tranny is measuring the speed, its only getting crank speed, and the one on the axle would get the at wheel speed, for they are rwd, and its in the rear diff. (obviously), so how could the one in the tranny get an accurate reading of the speedo? Its more logical that teh axle one would read the speedo... Thinking about this makes me think you just have to change the axle one....but i could be completly wrong....this is jsut my .02 cents on how i think it works
Old Feb 28, 2010 | 08:39 PM
xxxcowxboyxxx
thats what i thought but i was informed there was one there and i got unfer my truck and sure as sh*t there is a sensor on my tailshaft of my 46RE
Old Feb 28, 2010 | 08:41 PM
95RAM360's Avatar
95RAM360
re-read my above post, i added to the bottom of it
Old Feb 28, 2010 | 08:45 PM
xxxcowxboyxxx
ok that makes sense....except for my OD problem ?!?......sh*t maybe the two problems arent even reated i just assumed they were, and that the sensor in the tailshaft would fix it since its part of the trans ?
Old Feb 28, 2010 | 08:49 PM
95RAM360's Avatar
95RAM360
Think about, take what i said abov, and then in 98 they removed the tailshaft sensor....because thats not the one reading the speedo...Why would they remove that sensor if it reads the speedo......thats what i am thinking, and maybe somehow the one on the axle can effect the OD
