50mm Throttle Body on eBay...
Old Mar 3, 2010 | 05:51 PM
  #51
Activate's Avatar
Activate
Thanks for the quick answer.
Do you now who deliver them?
Thanks and greetings,
Erik.
Old Mar 3, 2010 | 11:58 PM
  #52
dodge15004x45.9's Avatar
dodge15004x45.9
This is the guys user name. J415 that has the tb for sale.
Old Mar 4, 2010 | 12:44 AM
  #53
dakotas ram's Avatar
dakotas ram
whats the diff in egr/non? ithought they were the same
Old Mar 4, 2010 | 12:50 AM
  #54
yakkier's Avatar
yakkier
I was wondering the same thing, because when you search for them they come up with two different part numbers, also put side by side on the bottom plate, the blowhole for the MAP is molded differently, it's in the same spot but it's recessed when the one's that do have egr's are simple holes right on the bottom of the plate
Old Mar 4, 2010 | 04:04 AM
  #55
bwdakrt's Avatar
bwdakrt
Erik.
Not in a 54mm. A stock TB can only go up to 53mm and anything above that will have to be billet. You could check with F&B.
Old Mar 4, 2010 | 04:21 AM
  #56
bwdakrt's Avatar
bwdakrt
Other than the throttle cable being different, they pickup the vac for the MAP sensor and EGR valve or evap system in different places on the TB. If you try to interchange them, you'll get a high idle issue.
This is a pic of the base of a non-EGR TB. Notice the vac notches in the base.
This is the EGR TB and notice there is no vac notches in the base. The vac comes from 2 small holes in the front inside of the bores.
Old Mar 4, 2010 | 11:50 AM
  #57
DukesOfHazzard's Avatar
DukesOfHazzard
Was this your prob the other night yakkier with your high idle, when you switched TB's. ^ learned something new ^
Old Mar 4, 2010 | 12:21 PM
  #58
lastrights's Avatar
lastrights
interesting never knew they were diffrent
Old Mar 4, 2010 | 03:11 PM
  #59
PurplDodge's Avatar
PurplDodge
Good info right there!!!
Old Mar 5, 2010 | 09:06 AM
  #60
jimmyp19's Avatar
jimmyp19
with running the risk of sounding stupid...how do you know which one you have...egr or non??? obviously without removing the tb...too cold outside
