What tranny is in my Ram?
Old Mar 2, 2010 | 07:56 PM
bondman35a's Avatar
bondman35a
Default What tranny is in my Ram?
Lost reverse the other day and from what I read on here sounds like it is time for a rebuild or replacement. The truck is a 2000 2500 4x4 360. Has a build date of 9/99. I have an add on local Craigslist for another tranny and would like to figure out what I can use. Is it the 46re or 46rh in my truck? I read on here that they cannot be interchanged due to difference in valve body controls. Also when did they change from the 46rh to the 46re? I have a few leads on other trannys but they are out of older (94,97) half ton 2wd trucks, not sure if those would work. One of the sellers said if it was a 2wd tranny you just had to bolt something else to the end to hook up to the transfer case? Some help would be appreciated, thank you.
Old Mar 2, 2010 | 07:59 PM
PurplDodge's Avatar
PurplDodge
YOu have a 46RE, a 46RH from a 1996-older truck will not work.
2WD transmission case is different. You would have to completely disassemble the transmission(s) and interchange the parts.
My $0.02, get it re-built or re-build it yourself.
Old Mar 2, 2010 | 08:03 PM
Maxx_Magnum's Avatar
Maxx_Magnum
or hit up the junkyards... gotta be one of those tranny's somewheres
Old Mar 2, 2010 | 08:49 PM
bondman35a's Avatar
bondman35a
THanks guys. Was the 46re in the 1500 with the 360s and 318 also or no?
Old Mar 2, 2010 | 08:53 PM
PurplDodge's Avatar
PurplDodge
Yes.
wjxavier's Avatar
wjxavier
yes, both.
edit: purpl beat me to it...lol
Old Mar 2, 2010 | 10:25 PM
J415's Avatar
J415
If you are interested in rebuilding it yourself like I am, PM me and I can send you the rebuild manual and video.
