Fuel Injector Cleaning??
Old Apr 28, 2005 | 03:53 PM
chaud's Avatar
chaud
Default Fuel Injector Cleaning??
My 95 Ram with the 5.2 seems to be straining for gas on cold starts. After the truck is warmed up it accelerates fine, but when cold it really struggles to pick up speed. Also, when the truck is first started and I pull it out of the garage in reverse and put the transmission back in drive it will die. It fires right back up though. Recently I have put on new plugs, wires, cap & rotor, new convertor. I thought I could replace the fuel filter, but found out it is in the gas tank and connected to fuel pump. Before I go the fuel pump route I was thinking about having the fuel injectors cleaned. The local minit lube can do this for less than $50 they said. Has anyone else had this done and is it worth it? Any other options that I'm missing here.
Old Apr 28, 2005 | 04:29 PM
steve05ram360's Avatar
steve05ram360
Default RE: Fuel Injector Cleaning??
you might try a higher concentration of BG 44K... mix 1 bottle with about 10 gallons in the tank and drive it till it's close to empty. see if this helps, for $50 bux I'd ask them how they do it. if they hook the injectors up to a machine, then yes, if they dump something in the tank, then no...
Old Apr 28, 2005 | 07:18 PM
chaud's Avatar
chaud
I looked the BG 44K stuff up and you can get fairly cheap on ebay. Would this stuff really work compared to the other cleaners you can buy at Wal-Mart or Autozone?
Old Apr 28, 2005 | 08:19 PM
steve05ram360
you can get it at most auto dealership parts counters and some automotive shops.
Old Apr 29, 2005 | 03:10 AM
chaud's Avatar
chaud
I took the TB off today and cleaned it up. I also took out the IAC(idle air control) I believe and the end of it was really dirty also. I got to looking in my dodge repair book and it talked about testing the IAC. It said to turn the ignition on and the IAC needle should move in or out. Mine did nothing so I assume its froze. Could this be whats holding the truck back?
Old Apr 29, 2005 | 03:44 AM
steve05ram360
yes, clean it, lube it or replace it
Old Apr 29, 2005 | 12:35 PM
Flynbryan19's Avatar
Flynbryan19
Is the IAC the sensor plugged into the throttle body? My truck seems to idle a little rough when first fired. I'd like to clean this along with the throttle body tonight.
Old Apr 29, 2005 | 01:24 PM
steve05ram360
the IAC is a valve that is used to control the air flow needed to maintain the idle. if it's dirty or sticky, you'll have poor idle and or stalling. usually a cleaning is all it needs.
