Cat. Convertor questions.
Old Mar 4, 2010 | 07:34 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by 96posidodge
i punched out my cat after my truck died and wouldnt start now the truck runs great iwould try it
You need to fix the lower intake now. As that's pretty much why the cat went bad. Do a search on here for "plenum gasket" and you'll learn all about it. Welcome to DF btw.
Old Mar 4, 2010 | 07:39 PM
  #22
meanwhitemopar's Avatar
meanwhitemopar
Originally Posted by Gerehead8
Wrong, Wrong, Wrong. Backpressure is always bad. Scavenging is always good. No one seems to understand this. Scavenging is the exhaust causing vacuum on the back of the exhaust valves so that the exhaust gases get sucked out rather than pushed out. To get good scavenging at low RPM's you need small pipes because there isn' much flow so to create the vacuum you can't have to much cross sectional area. What I think people get confused about is that if you have small pipes causing good scavenging at low RPM's when the RPM's go up and more flow is created so the small pipes restrict the flow and backpressure is created. Exhaust systems are tuned for an RPM range. Bigger pipes scavenge at high RPM and high flow, small pipes scavenge at low RPM and low flow.
Sorry for the rant, its nothing personal. It just REALLY p*sses me off when I see people talking about exhaust when they don't understand. Scavenging and backpressure are one of the least understood topics Ive ever seen.
i will admit, i am wrong, i know little about exhaust, but i do know about all this stuff and shouldnt have posted this... i am more of a suspention guy...
but now that i found a guy who is so good with it... how do i get good mid range power? thats where i always am... low to mid range...
Old Mar 4, 2010 | 07:56 PM
  #23
Gerehead8's Avatar
Gerehead8
You where on the right track. Just remember that bigger is not always better and keep the pipes on the small end to save that low RPM scavenging to keep the torque at low RPM's. Having true duals at 2" pipe is a good size for a stock or close to it motor (no heads, cams ect). Or using a single 2.5" pipe like the factory setup. Both are good from Idle to about 3K RPM. The problem is that both setups restrict top end power (start causing backpressure). A happy medium is usually a single 3" or dual 2.25" pipes. A good muffler or no muffler is a must. A good cat should theoretically not restrict flow much at all if it is sized properly.
I have Pacesetter shorties, a homemade Y-pipe with 2" primaries into a 2.5" collector, then a 3" in/out magnnflow cat, then 3" pipe to a flowmaster 40. I have dual 2.5's out to the back which are a little big (I bought years ago when I didn't have a clue). When they rust out I am going to a single 3".
Old Mar 4, 2010 | 08:00 PM
  #24
meanwhitemopar
ok so i have the pacesetter shorties, magnaflow hiflow y and cat ( stock setup but hiflow) and then a glass pack... to a dump...
would i be better off keeping the glass pack or adding a peice of 3" pipe in place of it and still dumping it?
Old Mar 4, 2010 | 08:08 PM
  #25
Gerehead8's Avatar
Gerehead8
The glasspack won't restrict flow so I would leave it. You said before that you wanted it loud. You could get a cutout so it would be loud but you could close it for work.
Old Mar 4, 2010 | 08:19 PM
  #26
meanwhitemopar
well like i said, i love being one of the senior guys here, and i do what i want, so i want it louder now, and it was, but i dont know if it was ok for it.. i just had the cat, to a turn down... like a foot later... would that hurt anything..
and sorry for the thread jack...
Old Mar 4, 2010 | 09:37 PM
  #27
98BlueSport's Avatar
98BlueSport
so if I can get the cat cut out. go ahead and do it? or put a new in. I really dont ahve the money for a new cat right now... so im leaning towards a diff. y-pipe and calling it good.
and for the record the 02sim is in the post cat sensor.
What i dont understand is why the motor ran fine for 448 miles all the way up there, and then acted up on the way home??
Old Mar 4, 2010 | 10:04 PM
  #28
meanwhitemopar
ok, for now, until you can save money for a good cat, cut yours out, take some rebar, and punch it out, and weld it back in... it will do the same thing...
why get a new ypipe? there shouldnt be anything wrong with yours...
and they tend to go in a hurry, there is ussually no warning.. and after that long, the cat just got hot and gave out... its not to uncommon
Old Mar 4, 2010 | 10:52 PM
  #29
98BlueSport
I think i got my money out of this cat. It is the original cat. never been replace and shes got 165,000 on the clock. decent if you ask me. Cat outlasted the trany. Trany went at 161,000
thanks for all the input
Old Mar 4, 2010 | 11:39 PM
  #30
mr freeze's Avatar
mr freeze
Talking
So if my truck runs bad I can go home and punch my cat and get 15 more horsepower? Poor kitty.lol
