Confused..
Old Mar 4, 2010 | 07:52 PM
DodgeRamYou's Avatar
DodgeRamYou
heres the video of how my truck runs..
http://www.youtube.com/watch?v=2f1rSdCYbMQ
Old Mar 4, 2010 | 08:01 PM
VEETEN's Avatar
VEETEN
Yeah glowing CAT is bad...
And you need some gas....LOL
meanwhitemopar's Avatar
meanwhitemopar
i cant view it, because im on a restricted comp... so im guessing just by the info, its a bad cat...
Old Mar 4, 2010 | 08:05 PM
jasonw's Avatar
jasonw
Site Moderator
See if the problems go away after replacing the cat. Keep us updated.
Old Mar 4, 2010 | 11:08 PM
DodgeRamYou
i will indeed keep you all updated & thanks for the help so far
Old Mar 5, 2010 | 12:34 PM
Sheriff420's Avatar
Sheriff420
A 3" in/out Magnaflow is only 70$ on summitracing.com, so if your factory cat is one pipe in and one pipe out then you can save 170$ on a cat.
Old Mar 5, 2010 | 08:04 PM
jasonw's Avatar
jasonw
Site Moderator
His 1996 will not be a one inlet/one outlet cat. It will be the "regular" two to one older cat design.
They didn't really start the whole larger single in/single out cat design until 1999 or 2000 ish. However, he can always have his exhaust changed to use it.
Old Mar 5, 2010 | 08:51 PM
Sheriff420's Avatar
Sheriff420
Well that bites. Time for a home made y pipe to make it a 1-in 1-out with a new o2 bung to relocate the upstream o2 sensor to the pipe and get it out of the cat.
Old Mar 5, 2010 | 09:47 PM
meanwhitemopar
well... now that i can look at the video... that is definatly the cat is bad.... WAY TO MUCH BACK PRESSURE to run right is what yoru experiancing... you can either get the 1 in 1 out at and make it work with like what sherriff is saysing or just buy a 2 in 1 out cat for the truck nd go that way...
Old Mar 6, 2010 | 01:38 AM
Sheriff420's Avatar
Sheriff420
ok, so it's 206$
http://www.summitracing.com/parts/MPE-23285/
