no yoru fine, as long as you put lock nuts on the mounts, your fine... if ya really worry about it, take a hammer, and bend them straight to the sway bar, youll be fine
well i was considering replacing my sway bar liks in a few weeks so i think i may flip the sway bar. i feel a bit safer doin it now since someone else has tried it, b4 this i though i was the only one out there with that idea lol
no, and accually, i know its safe, i drove with it like that from NY to NC and then drive around for a week with it on there like that before i had to hit an RTI ramp and took it off...
no, but they found the problem, the vlve body was bad, and due to that being bad, they need to replace the whole thing... to activate the OD they have to haave at least 60lbs of pressure, and mine was giving 16... so theres my problem..
they changed the valve body,,, and its thigns the shop is doing not me.. i dont know how to test all that stuff... the onething on these trucks i dont know, the trannies
