stupid question ...but need help
Old Mar 4, 2010 | 04:52 PM
metallatem's Avatar
metallatem
Question stupid question ...but need help
ok, what would make the Drivers side wheel wiggle ,not side to side , but top to bottom feels really loose , I just had ball joints done and breaks .
I know it was there before the ball joints but thought that would clear the problem up , any thoughts , would really help
thx again guys ....
Old Mar 4, 2010 | 04:53 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
wheel bearings are most likely shot
Old Mar 4, 2010 | 04:55 PM
DukesOfHazzard's Avatar
DukesOfHazzard
YUP ^ Mine fell apart in two pieces when i took it off
metallatem's Avatar
metallatem
ok thats what I was thinking but ...thought they would have noticed it
thats a quick DIY isnt it?
Old Mar 4, 2010 | 04:57 PM
xxxcowxboyxxx
yeah its pretty easy to change, take brakes off, axle nut, then the 3 bolts holding the bearing in from the backside, and then seperate it from the hub, you can take those 3 bolts out about halfways and then use an air hammer and socket on them to help seperate the bearing from hub
Old Mar 4, 2010 | 05:00 PM
DukesOfHazzard
https://dodgeforum.com/forum/2nd-gen...ring-swap.html here ya go same thing he said ^ , my axle nut was the only thing holding everything togeather
Old Mar 4, 2010 | 05:01 PM
metallatem's Avatar
metallatem
is it pressed on or just a bolt on fit?
Old Mar 4, 2010 | 05:03 PM
xxxcowxboyxxx
duke.....my buddies happened like that, first off he is no mechanic so he called me to look at his truck, when i pulled into his driveway his passenger tire was tilted about 9 inches lol. only thing keeping the tire on was the axle nut. good thing it broke when he was turning onto his road and not on the highway.....
Old Mar 4, 2010 | 05:05 PM
xxxcowxboyxxx
its just bolted on but can be a pain in the *** to get seperated sometimes depending on how long its been in there. my suggestion in once you do get it apart....change the U joint while your in there.
Old Mar 4, 2010 | 05:09 PM
DukesOfHazzard
I was on borrowed time and i drove around like that for awhile ,everytime i'd turn i heard clicking noise then turned into a louder banging noise. Kinda like lightly hammering on something. Yeah, could of been worse off, and it was the pass side also.
