how do you change a transfer case?
Old Mar 5, 2010 | 04:08 AM
1fast2liter's Avatar
1fast2liter
Default how do you change a transfer case?
i looked but couldnt find a thread on this.... is their a diy for it? thanks
Old Mar 5, 2010 | 06:15 AM
halfamil's Avatar
halfamil
I think you unbolt it, then bolt another on.
Old Mar 5, 2010 | 06:42 AM
PurplDodge's Avatar
PurplDodge
Would have never guessed!
Old Mar 5, 2010 | 07:27 AM
dhvaughan's Avatar
dhvaughan
i've not seen a diy on t-case swap, neither here nor on pavementsucks. check out on the jeep sites, pirate 4x4, offroad, etc forums. the ram is the same design as the jeep.
Old Mar 5, 2010 | 08:11 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Buy a Haynes manual
Old Mar 5, 2010 | 09:04 AM
sungod's Avatar
sungod
The top bolts on the transfer case can be a challenge. You need to lower the tranny down as much as you can then you may still have to use a stubby wrench on the bolt to get enough clearance to get them to turn.
Old Mar 5, 2010 | 11:11 AM
zman17's Avatar
zman17
They are actually a stud with a nut.(not bolts) Sometimes the whole stud/nut will come out as one. But yes, as Sungod said, the top ones can be a pain with out the right tools.
Old Mar 5, 2010 | 12:01 PM
Sheriff420's Avatar
Sheriff420
https://dodgeforum.com/forum/2nd-gen...placement.html
I didn't have any trouble with the top two nuts, I just used a socket wrench and a swivel attachment.
I think I read somewhere that you don't have to remove the crossmember to get the transfer case out, but I'm not sure on that one.
Since you're taking it off anyway, it wouldn't hurt to change the two seals in the DIY.
Old Mar 5, 2010 | 12:06 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Here's my 249->231/242 swap thread. Most of the info doesn't apply here, but use it for what it's worth:
http://www.jeepforum.com/forum/f13/n...pdated-685644/
Old Mar 5, 2010 | 12:39 PM
1fast2liter
awsome.. bolts shouldnt be no problem.. i just had tranny changed rebuilt so bolts and drive shaft should come out easy....
