46RE Transmission Starts in 3rd
Old Mar 5, 2010 | 10:46 PM
tj01ram's Avatar
tj01ram
Originally Posted by tj01ram
dealer got codes 1740 1756 and 1495
should mention 1495 taken care of right away - pump was disconnected
- with TCC i asked dealer to perform TCC Stall test and stated it would not apply to my truck
- i previously also had 1757 before going to dealer
Old Mar 16, 2010 | 12:56 AM
tj01ram's Avatar
tj01ram
so im looking at getting chrysler to pay for a re diagnisis since the dealer i went to did not perform tests according to dodge TSB - will see what other dealer finds
Old Mar 17, 2010 | 10:53 PM
countywacker's Avatar
countywacker
Is there any diffrent feeling in ur brake peddel? The only reason why i ask it seems like im starting with the same problem, but the peddel gets hard half way pressed in then lossens up again.
Old Mar 19, 2010 | 12:17 AM
tj01ram's Avatar
tj01ram
i have noticed that the brake pedal is stiff when i first start off - after a block or so goes back to normal though - the brake pedal is normally supposed to start working half to the floor but mine starts right from the top just starting out then half way after that - im still looking at a lot of different options for this issue - if you find anything tat works could you let me know? and if i figure a solution ill post as well - im contemplating switching to a 48 re transmission if it will bolt up
Old Mar 19, 2010 | 11:55 PM
tj01ram's Avatar
tj01ram
in my research i have found that the transmission is entering "limp mode" - so shifting is not my issue - it is something else causing the issue causeing it to enter limp mode to prevent transmission damage - i have received some information on the possibility that the wheel speed sensor may need replaced - which brings the fact up - I HAVE OVERSIZED TIRES!! 285/75/16 as opposed to 245/75/16 - so - the tires are brand new - same size as what was on before - i really dont want to spend money on another set of tires and i see i can purchase a calibrator for about $300 - IS THERE ANY CHEAPER WAY OUT?
Old Mar 22, 2010 | 06:44 PM
countywacker
Correction. I messed up. I meant the gas pedal not the brake pedal.
Old Mar 23, 2010 | 06:33 PM
tj01ram's Avatar
tj01ram
if your gas pedal is sticking you may have a binding issue somewhere with any of the 3 cables attached to the throttle body or a sticking throttle. id just try to move each cable by hand and eliminate any issues
Old Mar 23, 2010 | 09:29 PM
DODGEIT105's Avatar
DODGEIT105
Usually when the Governor pressure sensor is replaced it is a good idea to replace the Governor pressure transducer as well. it could also be the source of the 3rd gear start.
Old Apr 14, 2010 | 07:07 PM
KYHI's Avatar
KYHI
I have a 98 dodge ram with a 46RE trans..
Ran fine one night and was real slow on takeoff the next morning..
Autozone pulled a PO753 Code (seems to have gone bad overnight) - I replaced the govener pressure solenoid as they stated - but did not fix the problem, still pulling same code and only goes forward in third gear...
I was able to bypass the 3-4 shift and TC lockup solenoids with a jumper wire - thus by passing the "limp mode" (third gear forward only starts)
Wondering what solenoid you replaced??? And it sounds like you also have a bad Governor pressure sensor / transducer
Old Jul 31, 2010 | 03:44 PM
MikeMustang94's Avatar
MikeMustang94
Hey i have the same truck 01 ram 1500 with the same tranny prob.... what can i do please help im goen nutssss thanks
