Lost 5th gear
Old Mar 6, 2010 | 10:26 PM
evers310's Avatar
evers310
Unhappy Lost 5th gear
So we're coming back from a long trip and I'm about 220 miles from home when all of a sudden it feels like the truck jumps out of gear, except the gear shifter is still in 5th. I had to drive the rest of the way home in 4th. Not fun.
So am I correct in assuming that a transmission rebuild is in my future? What exactly happened? Manual transmissions are one thing I've never rebuilt before so I'm a bit in the dark on what exactly happened.
Thanks
Old Mar 6, 2010 | 10:59 PM
rumble_truck's Avatar
rumble_truck
Now, I'm not an expert on the 5spd, but there's something about them where the a bolt comes loose in the tranny and destroys everything. Maybe?
Old Mar 6, 2010 | 11:03 PM
Gord.'s Avatar
Gord.
Close, on the NV4500 the retaining nut works loose and can cause damage. I may be wrong, but if I remember correctly, it usually doesn't cause other damage when the nut falls off.
Gord.
Old Mar 7, 2010 | 03:53 PM
evers310's Avatar
evers310
So would it be a matter of dropping the trans, opening it up, and putting the nut back on?
Old Mar 7, 2010 | 04:02 PM
DukesOfHazzard's Avatar
DukesOfHazzard
https://dodgeforum.com/forum/2nd-gen...tmas-guys.html I wish i knew more about tranny's, but check out the tranny section , it's a little more detailed with procedures and pics for your manual tranny , might have something your looking for.
Old Mar 7, 2010 | 04:05 PM
zje400ex's Avatar
zje400ex
Since you have a diesel, you should try and post in the diesel ram section. They will be more aware of the fifth gear failure than most of us 2nd gens with 1/2 ton trucks.
I have heard people talking about this in the past so it must be a common problem. Actually, i think on TRUCKS a few weeks ago they did this repair on a 2nd gen cummins they were working on.
