46rh Shift Kit?
Old Mar 7, 2010 | 12:30 AM
blong4life's Avatar
blong4life
Default 46rh Shift Kit?
Well, Going to be pulling the pan soon to replace the trans temp sensor (get rid of the code), and while I am in there I want to whip in a shift kit.
Anybody recommend any shift kit? Also anything else I should do while I am up there (other than adjust those bands)?
Once I do that, going to flush it at work, fluids dark but not burnt, not sure if it's the original tranny or not (134k).
Old Mar 7, 2010 | 12:34 AM
yakkier's Avatar
yakkier
2wd or 4x4
Old Mar 7, 2010 | 12:39 AM
DODGEPWR's Avatar
DODGEPWR
Just a tip..
People say not to touch the bands. Take it to somone for that.
Old Mar 7, 2010 | 12:45 AM
blong4life's Avatar
blong4life
4x4. Who would I take it to?
Old Mar 7, 2010 | 12:51 AM
J415's Avatar
J415
a shop.
Old Mar 7, 2010 | 12:55 AM
blong4life's Avatar
blong4life
Dunno of any shops to trust, I do all my own work.
Old Mar 7, 2010 | 02:15 AM
dakotas ram's Avatar
dakotas ram
i have a 95 with 46rh and i tossed a transgo jr kit in mine.......+1 on not touching the bands yourself
Old Mar 7, 2010 | 09:27 AM
95ram5.9's Avatar
95ram5.9
Adjusting the bands is a piece of cake, just make sure you have an accurate in. lb. torque wrench. Bands that are not adjusted properly will cause the transmission to bind and shorten the life of the clutch plates, and cause excessive heat in the trans.
