Transmission question
Old Mar 7, 2010 | 05:21 PM
ClubMike's Avatar
ClubMike
Default Transmission question
I have the V-10 set up with a 4 speed auto trans. I found this part in the bottom of my trans pan when I went to change the fluid today. Can anyone id it for me?
Only issue I am having with my trans is it will not go all the way into park. Would this part have anything to do with it?
thanks
Mike
Old Mar 7, 2010 | 05:41 PM
DukesOfHazzard's Avatar
DukesOfHazzard
page 21-685 in transmission section of the ^service manual, shows a pic of it being a strut? check out the DIY or FAQ'S section up top to get it.
Old Mar 7, 2010 | 05:48 PM
DukesOfHazzard
https://dodgeforum.com/forum/2nd-gen...ml#post2034361 here ya go.
Old Mar 7, 2010 | 05:58 PM
ClubMike's Avatar
ClubMike
Default you are right
That is the part, now here is the next question, can I put this back in with the trans still in the truck?
thanks for your help, what a great site.
Mike
Old Mar 7, 2010 | 06:05 PM
DukesOfHazzard
I'd think so if it was in the pan it could go back where it was, i dont know you have the 47re a little different then mine(46re) i would have to take it apart and get a more detailed idea where it goes. But i would think if it fell off into the pan it could go back, just my
Old Mar 7, 2010 | 10:49 PM
J415's Avatar
J415
The part you pictured is the front band strut. it goes against the band and the lever You have to drop the Valve Body to install it.
Here's an idea on how to do it: http://joelsgarage.blogspot.com/sear...-paginate=true
Old Mar 14, 2010 | 08:17 AM
ClubMike's Avatar
ClubMike
Update, my part went back where it is supposed to go, adjusted the band, and filled it back up with trans fluid and it runs great!!! Ramzilla is still kicking, yeah baby!!!!
thanks for the advice
Mike
Old Mar 14, 2010 | 01:33 PM
DukesOfHazzard
So do you have a Ramzilla tranny or is that just what you call your truck?
Old Mar 16, 2010 | 07:56 AM
ClubMike's Avatar
ClubMike
Default ramzilla trans
That is what I call my truck, I also refer to it as big blue. Is the ramzilla trans any good? I have never heard of it.
Hey, thanks for your help on this stuff.
Mike
Old Mar 16, 2010 | 11:57 AM
DukesOfHazzard
http://www.transmissioncenter.net/dodge.htm Check it out , im prob gonna go core and rebuild , something to learn on in the garage,< while my trannys still good. Or Dr Evil Trans or APS or Apc < not sure about that one.
