replaced u joint, axle leaking
Old Mar 9, 2010 | 03:52 PM
lord0fsal3m's Avatar
lord0fsal3m
Default replaced u joint, axle leaking
hey i just replaced that obliterated u joint on my front pass, and i noticed its still leaking from the axle, how long will it keep leaking? i hope there isnt a problem with my axle seal, im really not in the mood for that.
Old Mar 9, 2010 | 04:13 PM
dodge15004x45.9's Avatar
dodge15004x45.9
it will leak until it runs out of fluid like mine is, and yes its the axle seal no if and's or buts about it.
Old Mar 9, 2010 | 04:22 PM
pavement_hater's Avatar
pavement_hater
I developed an axle seal leak on my drivers side last year a couple months after I had the axle out. I let it leak for a few weeks checking the fluid every couple days. It finally got to the point where it stopped. The fluid was a little low but not in any danger to the gears. A month or so after that I topped it off with Lucas and haven't had a problem since. I can't say it will work for you, but atleast you have the easier side to do if you have to change seals.
Old Mar 9, 2010 | 08:03 PM
dhvaughan's Avatar
dhvaughan
mine leaks if full, but when the fluid level gets about an inch below the fill plug it quits leaking.
Old Mar 9, 2010 | 08:09 PM
95RAM360's Avatar
95RAM360
both of mine were leaking for about 6 months, went off-roading with it, underwater, a bunch of stuff, now im replacing the seals...and to tell you the truth its not a hard job, only problem i have had is taking out the carrier in the front diff, which i managed to do tonight....other than that its pretty easy...Get a nice big breaker bar though, it makes things go so much quicker...I had the entire front end ripped apart in an hour and a half (brakes, axle shafts, cad housing/shaft, wheel bearings, driver tie rod end, and diff cover.)
Old Mar 9, 2010 | 11:16 PM
highlander73's Avatar
highlander73
When i replaced the ball joint and had the axle out WITHOUT draining the pumpkin first some fluid leaked into the axle tube between inner and outer seals. For the next 1000 miles fluid was dripping from the outer seal/ball joint and flung about the wheel well. I asked a mechanic to change the inner seal and he said to wait to see if it stops "leaking" first as it may not be the inner seal. He was right - 1000 miles later no more leaking, pumpkin is still full of fluid.
Might be your problem given you just did u-joint work.
Old Mar 10, 2010 | 09:36 AM
iwhitne's Avatar
iwhitne
both of mine are leaking... I'm taking her in to have all new u-joints and new seals.. and I might get my door fixed finaly!
Old Mar 10, 2010 | 09:47 AM
Maxx_Magnum's Avatar
Maxx_Magnum
you guys got me thinkin now.... I changed both wheel bearings and 1 front u joint a few months ago.... I haven't noticed and leaking but I haven't really looked lately either. It's on my list now anyways
Old Mar 10, 2010 | 09:57 AM
Sheriff420's Avatar
Sheriff420
Did you clean the axle tube before you put the axle back in?
When you pull the axle, you drag some fluid into the tube and if your seal isn't leaking and you didn't clean the tube then it's just a matter of time before it stops.
Old Mar 10, 2010 | 11:05 AM
95RAM360's Avatar
95RAM360
both of mine left puddles next to the tires the size of a gas cap every night/ when i checked the next morning. I knew mine were bad. but i got new ones in now
