Old Aug 5, 2015, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
4x4 actuator ?
Old Mar 10, 2010 | 12:14 AM
quackaddict's Avatar
quackaddict
Default 4x4 actuator ?
Is it supposed to be loose and move by hand. Trying to figure out why I have no 4x4. I checked the vac lines and they appear to be ok. But I noticed a lot of crud where the actuator is and noticed I can turn it a good 1/4 turn by hand. Just wondering if it could be the problem?
Old Mar 10, 2010 | 03:58 AM
lblair04's Avatar
lblair04
If your talking about the cylindrical part on the side of it...it will move a little bit. It is kept from spinning by a tab on the frame of the CAD and a bolt-type part on the end of the cylinder. Dont know how to describe it without a pic.
Sometimes, the fork in the CAD will break. Also, there is an actuator on top of the transfer case that can go bad...its what the vac lines connect to on top of the t/c.
Is your light just not turning on or what? Have you tried putting the truck on jackstands (all 4 tires off) and putting it in 4x4 and seeing if anything happens? Does your driveshaft spin?
The CAD's arent the best design for 4x4 in the first place. Before replacing the CAD, I would buy a posi-lok unit...they are around $200 and are more reliable.
Old Mar 10, 2010 | 07:19 AM
dhvaughan's Avatar
dhvaughan
the whole story here.
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Mar 10, 2010 | 07:35 AM
hammerhead1985's Avatar
hammerhead1985
sometimes the small e-clips that hold the fork on the shaft can break or come off. then he shaft will move and close the switch making the 4 X 4 light come on when really the fork didn't slide the collar to lock it in. If the light comes on but no 4X4, I'd check that first. You'll see a small groove on both sides of the fork and there should be an e-clip on both sides
Old Mar 10, 2010 | 04:33 PM
quackaddict
I get no 4x4 light in or out of 4x4. put it on jackstands not in 4x4 you turn the wheel driveshaft does not spin but you can spin the driveshaft by hand. Lock it in 4x4 turn the front tires driveshaft still doesn't spin.
I did notice when not in 4x4 I can turn the front driveshaft by hand, but once you put it in 4x4 it will not spin.
They give us straight axles when everyone else is IFS then give us a crappy engagement system......lovely.
Just read Dhvaughn's link, from what I read the T/C is engaging when I move the lever because the drivshaft will not spin by hand so I need to do further diagnosis to see if it is the fork or the motor............ahhh fun
Old Mar 10, 2010 | 06:04 PM
95RAM360's Avatar
95RAM360
i just did my seals today, and the actuator is like this....there is a shaft that goes into the carrier, and it has a hole in the top (in cad area) Then theres another shaft that goes through (shaft that holds wheel bearing/with u-joint) that has a spool that fits n the hole of the other shaft. In between them (CAD area) there is a small gear that goes around the outter shaft. then the actuator that goes in has a fork that fits around the smaller gear. when you pull the lever, it moves the small gear so its on both shaft splines, thus engaging 4x4.
how that helped....i just learned how they worked today, and thought i would share lol
Old Mar 10, 2010 | 06:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you read the link dhvaughan posted and you still can't figure it out, I have a Posi-lok if you would like to purchase it.
Old Mar 10, 2010 | 07:16 PM
meanwhitemopar's Avatar
meanwhitemopar
does anyone know where i can buy just the cable? i bought the posi lock kit, and then brought all my stuff from NY to NC and i lost it in the move... my parents say its not in NY, and i looked all aorund my house in NC, and cant find it....
sorry for the thread jack, but it may be the vac source... it doesnt seem like ti but pull the lines of the diafram on the axle, and in 2wd one should hve vac, then in 4wd the other should have vac,,, and a good amount too, like enough to pull your finger to it... so... it may be something there.. fix for that is the posi lock kit
Old Mar 10, 2010 | 09:28 PM
dhvaughan's Avatar
dhvaughan
^try to contact posilok for spare parts. maybe you'll get lucky at a reasonable price, but don't be surprised if the damn cable is a much as the whole kit. there's not a lot to the kit other than the cable - just the button, button bracket, cad cover, light switch, fork piece.
Old Mar 11, 2010 | 12:58 AM
lblair04's Avatar
lblair04
As far as the cable goes...I built a posi lok for my Jeep...I used a throttle cable with the locking t-handle. Might be able to do this??
I have known the vacuum acuator on top of the t/c going out. It isnt very difficult to replace...its just threaded in the top and should only be around $20.
