Quest. about 02 sensors
Old Mar 11, 2010 | 04:14 PM
snooked321's Avatar
snooked321
Question Quest. about 02 sensors
Ok i have a engine light (bad 02 sensor) am i supposed to just geuss which one it is or is there some way to troubleshoot these? 2001 dodge ram 5.9. 105000 miles It started hapening after the the cat was replaced.
Old Mar 11, 2010 | 05:19 PM
97tn4x4's Avatar
97tn4x4
It's more than likely the upstream one. The one behind the cat doesn't really do anything.
zman17's Avatar
zman17
Retired Moderator - RIP
How did you check the code? The code # tells you which sensor is faulty.
Old Mar 11, 2010 | 05:20 PM
Twisted Metal's Avatar
Twisted Metal
If you had the cat replaced, you should have had the O2 sensor changed as well. You mentioned the CEL on, is it giving a code? More than likely, its the pre cat one that is bad. Be careful when purchasing one, the connectors are different, depending on when the truck was built. NTK(NGK) and the OEM sensors seem to work best with our trucks.
Old Mar 11, 2010 | 05:54 PM
zman17's Avatar
zman17
It does serve a purpose and can cause the CEL to come on regardless. Hence the question about the code #. Why Guess.
Old Mar 11, 2010 | 06:15 PM
snooked321's Avatar
snooked321
Ok the code is P 0420.
Old Mar 11, 2010 | 06:22 PM
zman17's Avatar
zman17
Here's what a simple search through the FAQ section will get you, https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Mar 11, 2010 | 06:37 PM
snooked321's Avatar
snooked321
P0420 1/1 Catalytic Conv Eff were is this exactly pointing me?
Old Mar 11, 2010 | 06:38 PM
zman17's Avatar
zman17
Post cat sensor.
Old Mar 11, 2010 | 08:12 PM
dhvaughan's Avatar
dhvaughan
http://www.obd-codes.com/p0420
http://wiki.answers.com/Q/What_does_code_p0420_mean
hold on.
420 means the post cat and pre-cat readings are too similar, which means the cat is not working. it doesn't necessarily mean that one or the other is bad. this is a common code for people who remove or gut their cat.
