Next Project
Old Mar 12, 2010 | 09:38 AM
95RAM360's Avatar
95RAM360
Default Next Project
Ok im starting a new thread for im going to start a new section on my truck. I need some advice on what i should do next.
1. Rockers, and Doors: As you can se from my pic, they need some work.
2. Rear Main Seal, Tranny/ Transfer case seal: Found they were both leaking a little bit yesterday...its not bad yet.
3. Timing Chain: at 200K, i dont know if its been changed, but there wasnt slack when i replaced gasket 4 months ago....better safe than sorry.
Which one should be my next project? and whichever one is chosen, i will post all the updates in this thread.
Old Mar 12, 2010 | 09:44 AM
Maxx_Magnum's Avatar
Maxx_Magnum
do the timing chain next.... I wanna change mine when I do the plenum so take pics!
Old Mar 12, 2010 | 09:53 AM
95RAM360's Avatar
95RAM360
ok....im going to take the first 7 replys on what i should do, and whichever has the most is what im going to do...7's my favorite number thats why i chose that.
Old Mar 12, 2010 | 09:59 AM
Weldor's Avatar
Weldor
Rockers/Doors
Old Mar 12, 2010 | 10:18 AM
Gerehead8's Avatar
Gerehead8
+1 on rockers/doors.
Old Mar 12, 2010 | 10:23 AM
zje400ex's Avatar
zje400ex
5" suspension lift! Just kidding. If I were you i'd take care of the doors. Seems like you've got the truck running good so start on the outside.
Old Mar 12, 2010 | 10:28 AM
jimmyp19's Avatar
jimmyp19
doors
Old Mar 12, 2010 | 10:39 AM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
i would make sure that its in top mechanical condition b4 i worry about cosmetics, but if like your saying its running good and there are no immediaate fixes needed, start the doors and rockers
Old Mar 12, 2010 | 11:10 AM
WaynesWorld's Avatar
WaynesWorld
I got to agree with cowboy
Old Mar 12, 2010 | 11:16 AM
95RAM360's Avatar
95RAM360
truck runs excellent, nothing is loosing noticable amounts of fluid...the Rear main leak isnt even making it to the ground, its just wet near the starter, and the tranny/transfer case area is leaking very small amounts, its wet on the bottom portion, but not enough to drip down. Fluids are right to appropriate levels. Shifts mint, idles mint, oil psi is at 55 when on gas, it goes excellent.
So i guess that majority is rockers and doors....
I will tackle into that once the weather clears...Lots of pics to come
