Tranny fluid question. How screwed am I?
Old Mar 12, 2010 | 06:10 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by 95RAM360
question about check valve...i dont know if PO did it, but mine does not look like any of the pics in that write up...i have a rubber line going into the radiator spout. do they come stock like this?
check valve is at the end of the hard line on the frame rail.
the factory setup is two rubber hoses with fancy quick connect fittings at the rad and permanent crimps at the hard lines (like hydraulic hoses). if the either end is clamped, you have a modified hose (which is fine).
Old Mar 12, 2010 | 07:07 PM
95RAM360's Avatar
95RAM360
cool thank you, mine has been fixed then
