rear drums
Old Mar 12, 2010 | 08:49 PM
Laramie1997's Avatar
Laramie1997
If all else fails, jack the truck up and put one lug nut back on the stud. Then start truck and let the motor idle dropping the trans into D. Jab the breaks a couple of times and watch and see what happens.
Old Mar 12, 2010 | 08:55 PM
blong4life's Avatar
blong4life
Originally Posted by dhvaughan
hmmm, i don't have a 2500, but if i'm reading the haynes manual right, it just pulls off the same as a 1500, other than being bigger and heavier.
i think the axle has to come out of the 2500 front to get the rotor off.
Someone told me you had to pull the axle, I am not really sure though, I'll check mine out this week.
Old Mar 13, 2010 | 02:36 PM
elcheeko's Avatar
elcheeko
itsa 1/2 ton and i took the metal clips off and throgh em away i thought why does it need em if the wheel holds the drums on
Old Mar 13, 2010 | 04:57 PM
dhvaughan's Avatar
dhvaughan
the clips were probably installed at time of mfg to hold the drums on during transportation and storage. then just left on.
