detent cable adjustment
Old Jun 3, 2012 | 12:43 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by dodge fan 001
95 ram 1500 5.9 engine no button on the detent to adjust it. automatic trans no light on just started yesterday after I got off the highway... jim
Try checking for any stored codes, http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Jun 3, 2012 | 02:34 PM
  #22
dhvaughan's Avatar
dhvaughan
i don't know if this applies to your 95 or not, but when the pcm determines there's a problem, it puts the transmission in limp mode, which starts out in 2nd gear.
you should be able to shift to D1 or L1, whatever its called and get it to respond. you might? have to disconnect the electrical connector, or, reset the pcm by disconnecting battery and turning on headlights for 30 sec.
