Dead Dash
Old Mar 12, 2010 | 03:51 PM
dailydriver's Avatar
dailydriver
Default Dead Dash
Hi everyone, long time looker, first time poster. Anyway, I tried the search and had no luck, so here's my problem. Over the last few weeks, a couple times when I tried to start my truck, everything would light up like normal. When i moved the key to start, I would hear a click and the entire truck would go dead. I would turn the key off and wait a few seconds and it would usually come back on like normal, but everthing is reset (including the trip odometer). Just today, it wouldn't reset itself and I had to take the car to work. Any ideas or similar experiences from anyone here?
Thanks for the help.
In case my signature doesn't come up, its a 98 1500 w/318/auto/4x4 and just turned over 200k on the odometer.
Old Mar 12, 2010 | 03:59 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
sounds like the cluster went bad
Old Mar 12, 2010 | 04:50 PM
Maxx_Magnum's Avatar
Maxx_Magnum
or maybe the computer?
Old Mar 12, 2010 | 05:32 PM
95RAM360's Avatar
95RAM360
So the truck still starts and runs?
If not id say theres a bad connection at the battery or alternator.
If it does run, id check your wiring,,,when i ripped apart my harness i found 5 bad wires.
Old Mar 12, 2010 | 06:14 PM
dhvaughan's Avatar
dhvaughan
with battery disconnected, i'd unplug and replug the computer.
then clean the battery connections.
see if that helps any.
Old Mar 12, 2010 | 06:29 PM
Daily Driver's Avatar
Daily Driver
Sounds like the battery terminal is losing connection.
