1997 4x4 OD problem HELP!
Old Mar 14, 2010 | 02:26 PM
Jackstand123's Avatar
Jackstand123
Default 1997 4x4 OD problem HELP!
Hello all. Ok a little info to get started . I bought a 1997 1500 4x4 5.9 ext cab. 3 mts ago and have had a heck of a time figuring out the problem with the overdrive. When I get to 50 - 55 mph it stutters or kicks in and out of OD. If I turn off OD it goes back into Drive and seems ok. I have changed the torque converter had transmission rebuilt ,changed TPS sensor . My wife is ready to kill me so I am doing what I should have done in the beging asking for help from folks who have went through this. Yes , I should have brought it to a trans shop to start with. but I didn't . Now I don't want to keep putting out $$$ . Please any help Oh and another part that may be helpful the speedometer is working sometimes.....I Bought a speed sensor too replaced and did not help still the same works for a bit and then does not .... Thanks Ron
Old Mar 14, 2010 | 02:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Welcome to DF! You have to do a search here! This topic has been gone over a thousand times. Want a quick answer from some one? It will only be a guess. There is so much info on tranny problems your head is going to spin.
Old Mar 14, 2010 | 05:07 PM
Jackstand123
I know I've read a ton of different threads ...just trying to get a best educated guess from some one having the same problem. And thanks been reading the threads for 3 mts just this being my first post so thanks for the welcome.
Old Mar 14, 2010 | 05:54 PM
95ram5.9's Avatar
95ram5.9
Do you know if the solenoids were replaced or atleast tested to be ok when the tranny was rebuilt?
Old Mar 14, 2010 | 07:03 PM
Jackstand123
They were not replaced .. But he said they tested ok . Except for speed sensor replaced.
Old Mar 15, 2010 | 05:08 PM
Jackstand123
Ok I feel Stupid now... I took truck to good transmission shop after they looked it over good he said the problem is not your transmission its the misfire in cyl 4 and 5 .... The valve s r bad ....and the mis firing is leading me to think it is a transmission problem... So I'm gona have to look around for a motor as this one has 220k and too expensive to rebuild right know since I just wasted my money on trans...
Old Mar 15, 2010 | 06:28 PM
dhvaughan's Avatar
dhvaughan
i'd get a 2nd opinion on that.
run a compression test on the engine. you may or may not have bad valves. you may or may not have cracked head. do you have any CEL codes that support the misfire diagnosis? that still doesn't explain why it kicks in/out of OD.
Old Mar 15, 2010 | 06:40 PM
duxndogs's Avatar
duxndogs
when my 99 had these symptoms i to thought damn junk tranny.well it turned out to be a bad throttle positioning sensor,swapped it out all good.
but now my tranny is really junk.
Old Mar 15, 2010 | 07:27 PM
Jackstand123
I Got the same codes from them as auto zone just $60 cheaper at auto zone.I remember one of the codes was P0304 and a random misfire and the # 5 as well forgot the codes #ers. He explained that is was not really kicking in and out of overdrive just felt as it was from the misfiring . I'm going to get a compression check and get back to you guys.
Old Mar 15, 2010 | 07:31 PM
JG96 Ram's Avatar
JG96 Ram
it can be anything it has happened to me twice. one time it was dirty injectors and the second time i had a plug wire melt to the exhaust manifold.
