Suggestions for sparkplugs and wires :D
Old Apr 30, 2005 | 11:00 PM
titter's Avatar
titter
Default Suggestions for sparkplugs and wires :D
just wondering what every else uses? i am using 8.5mm msd's and ac delco plats in my camaro, i have read some of you are using the same wires but different plugs my truck has a miss so ima start with a tuneup, and go from there. also what fuel filter are you all using? i think i am going to need a new coil though, because its having trouble starting and the misfire could be coming from that. just weird as i slowy give it gas it revs up then if i keep the throttle at about 30% the rpms start bouncing really bad ... so thanks for any help in advance.
Old Apr 30, 2005 | 11:31 PM
vlsun's Avatar
vlsun
Default RE: Suggestions for sparkplugs and wires :D
i just got mopar wires and ngk v-power plugs.
Old May 3, 2005 | 07:52 PM
cfmiller58's Avatar
cfmiller58
i use autolite plugs, one step colder than stock. also i have accel 8.8 wires with an accel coil n the works with rotor n cap n all that. runs great.
Old May 3, 2005 | 08:09 PM
Silver_Dodge's Avatar
Silver_Dodge
I haven't installed them yet, but I am going with:
- Autolite 3923 (that's the one that is one temp range colder then the stock plug), not platinum
- Mopar Performance Wires, 7.5mm is all they make
- Accel cap and rotor with brass components
Old May 3, 2005 | 11:20 PM
RebelRam04's Avatar
RebelRam04
Just got my 2nd Gen Ram but I had a similar problem in a Honda Del Sol I owned years ago and it turned out to be the plugs, apparently Hondas don't like Platinum +4s.
Old May 4, 2005 | 11:51 AM
RedRocket's Avatar
RedRocket
I have been getting the same problem, steady gas, but the RPMs are bouncing all over the place. I am looking to replace the fuel filter, does anyone know how much work that is?? I am also looking to replace the plugs, and wires. Any other things I should look at replacing? I have a 99 1500 4x4, 5.2L with just over 100,000Km
Old May 4, 2005 | 03:31 PM
steve05ram360's Avatar
steve05ram360
NGK ZR5F-11 plugs gapped @ .040, msd 8.5 wires, brass cap & rotor.
Old May 4, 2005 | 05:32 PM
Flynbryan19's Avatar
Flynbryan19
ORIGINAL: RedRocket
The fuel filter is in the tank along with the pump.
Old May 5, 2005 | 01:55 PM
steve05ram360
ORIGINAL: cfmiller58
there have been complaints of the accel coils (direct bolt on ones) that have been failing during cold weather, check it out...
MSD makes one that is also a direct fit on the dodge motor. for '98 and up you'll need a wiring harness adapter... Accel makes one p/n acc-140021ah (summit p/n) for $22 bux.
