Steering box question
Old Mar 15, 2010 | 08:49 AM
gchase2's Avatar
gchase2
Default Steering box question
Guys,
I need to replace the steering box in a 1998 Ram 1500 4X4 and I was wondering if the the steering box in the Sport version was different from the regular truck ? I was hoping I could get a tighter ratio with a little better feel.
There is a long story that goes with this and as soon as I fix the problem I will post all about it. Maybe it will save soemone else a lot of aggravation (and Money).
Thanks Gary
Old Mar 15, 2010 | 09:58 AM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
only thing different about a sport is cosmetics outside.....so the gearbox's will be identicle
Old Mar 15, 2010 | 10:38 AM
zman17's Avatar
zman17
Retired Moderator - RIP
IIRC, you can put a box in from a 3500, but I don't know the ratio difference.
Old Mar 16, 2010 | 08:46 AM
olyelr's Avatar
olyelr
Yep, the sport steering is the same.
1 ton steering gears have a different ratio, which sounds like what you are after. They also bolt right up. You could also try to find one for an off road model truck, as they had a slightly different ratio. Not sure on the difference of each, but there is some.
When I replaced mine a few years back, I got the one from PSC that is variable rate ratio. They had that one and a stock replacement. They recommended the variable ratio box only with a heavy duty truck or one with large tires due to the very low "road feel". It took me a while to get used to it cause it steers sooooooo damn easy, but now I love it.
Old Mar 16, 2010 | 10:51 AM
Aubrey's Avatar
Aubrey
I can't remember the ration off-hand right now but the 1500 has a variable ratio where the 2500 and 3500 did not.
