New power steerin pump - still not working
Old Mar 15, 2010 | 10:40 PM
siberjon's Avatar
siberjon
Default New power steerin pump - still not working
Hey Guys,
I was having trouble with the power steering pump. Lots of noise and it would only work sometimes when I reved up the engine.
I just finished replaceing it and I have no power steering.
I bled the system:
Took off return line from the pump, pluged the pump end.
started vehicle for 2 seconds and watched all the old stuff shoot into the bucket from the return line.
re attached and ran through left to right process
took off line and bled again.
I have gone left to right a ton of times with the steering wheel and I still have No power steering... just very tough manual.
any thoughts?
Could it still be air?
Old Mar 15, 2010 | 11:04 PM
mctdi's Avatar
mctdi
First thought is are th seals in the gearbox OK?
Second thought is the relief valve in the pump working/set right?
Air should be mostly worked out with a couple of turns hard right and hard left.
Old Mar 15, 2010 | 11:06 PM
siberjon's Avatar
siberjon
i have not checked the seals in the gear box.... not sure how to.
I am not sure on the relief valve but when i started the truck with the return hose disconnected it came out fast and hard...
Old Mar 16, 2010 | 09:36 AM
mctdi's Avatar
mctdi
Does pump change sound as the wheel is turned? You might need to find someone with a tee fitting for the pressure line, and 3000 PSI gauge. Most systems are like 1200 to 2400 PSI.
Old Mar 16, 2010 | 10:54 AM
Aubrey's Avatar
Aubrey
Maybe your pump is ok and it's your other steering components?
