What valve is opened in "D" and not in "1" gear?
Old Mar 15, 2010 | 11:31 AM
98formulaLS1's Avatar
98formulaLS1
Default What valve is opened in "D" and not in "1" gear?
I have a stumble in 1st gear, but only when the truck is driven in "D" drive. When I manually shift to "1" first gear, it doesn't exist at all. I've been driving around all week like that.
Any suggestions?
Old Mar 15, 2010 | 12:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the "accumulator valve spring" on the valve body is broke. Seems to be pretty common from what I hear.
Old Mar 15, 2010 | 01:55 PM
98formulaLS1
ok, I'll look into how to check that. i was really hoping that it would be some sort of electronic valve or bad sensor that causes this problem. I did read in the service manual however that the rear clutch is engaged when the shifter is in 1, and not engaged in D. I don't know how that would effect things though.
Old Mar 15, 2010 | 02:06 PM
zman17's Avatar
zman17
I'm no tranny expert so I'm not much help! LOL But how does the speedo work and do you have an ABS and Brake light on? And have you had it checked for codes?
Old Mar 15, 2010 | 02:15 PM
98formulaLS1
it doesn't have any lights, i have tried to pull any codes, and the speedo is a tad bit fast.
Old Mar 15, 2010 | 02:27 PM
zman17's Avatar
zman17
For a fairly cheap fix, you could try replacing the speed sensor on the tailshaft. Or the TPS can be the culprit.(do a search here). This may help also https://dodgeforum.com/forum/2nd-gen...ise-speed.html or not! Whatever! You really need to search around this site and you just might find the answer, good or bad.
Old Mar 15, 2010 | 09:51 PM
Gerehead8's Avatar
Gerehead8
It sounds like the overrunning clutch is turning. In 1st the low/reverse band holds and in breakaway low the overrunning clutch holds. The overrunning clutch is a mechanical one way clutch so if it is going bad the tranny will need a rebuild.
Old Mar 16, 2010 | 01:20 PM
98formulaLS1
ok so i've spent hours and hours reading the entire A518 service manual, watching the video, and reading that one guys rebuild PDF. After learning all about the different clutches and problems associated with them, I feel confident that my problem is not inside the main unit or OD unit, but in the Valve Body. I was planning on changing the filter, fluid, and adjusting the bands this weekend, so now I also want to install Sonnax Sure Cure tranny reconditioning kit. I hope that will help, in addition to a new TPS.
I'm stoked about it!
Old Mar 16, 2010 | 06:09 PM
98formulaLS1
crap it just registered codes P0740 and P0783. I think I need to rebuild now. :-(
