Noise from the Transfer Case...
Old Mar 17, 2010 | 08:30 AM
mnewbolds's Avatar
mnewbolds
Default Noise from the Transfer Case...
I just recently engaged my 4 wheel and immediatly there was a loud squeel coming from the transfer case. I looked into having a shop rebuild it, but they said it would run about $1500. Too rich for my blood and I have a camping trip coming up, I NEED MY 4 WHEEL! Is this something that I could do at home? Would it be worth it to rebuild it or purchase a used one. I would hate to buy one and have IT fail too. Any and all info will be appreciated. Cheers to the Irish!
Old Mar 17, 2010 | 08:52 AM
95RAM360's Avatar
95RAM360
usually these transfer cases are bullitproof....if you get one from a junkyard ( http://car-part.com ) it should be able to hold up for a while....a used one with a warentee...
Old Mar 17, 2010 | 08:53 AM
mnewbolds's Avatar
mnewbolds
The only ones I could find in my area are different gears from what I have. ...If only I won the lottery.... But the guy I spole with at the shop said something about a "fork anchor" ???
That website has always been a lifesaver. Couldn't tell you how much I've used it, but I just hate thinking that I'm buying something somebody has already beat the living ****e out of.
Old Mar 17, 2010 | 09:00 AM
95RAM360's Avatar
95RAM360
just put it in until your trip is ovr, and while you have that one in, rebuild your old one yourself....thats what i would do.
Old Mar 17, 2010 | 09:05 AM
mnewbolds's Avatar
mnewbolds
Sounds like a good idea, at least that way if I break it, oh well... Is it too involved of a job for a drivetrain rook like myself is what I'm wondering. I could rebuild a motor, but have to change my shorts when it comes to trans/t-case repiar.
Old Mar 20, 2010 | 03:06 PM
mnewbolds's Avatar
mnewbolds
I found a few 231 T-cases from Jeep Cherokees. Are they any different from the Dodge 231's?
Old Mar 20, 2010 | 03:54 PM
meanwhitemopar's Avatar
meanwhitemopar
im asking the same thing.. and these transfers are not bullitproof... they are a weak link... but not so much on stock parts... i dont know what your problems could be, other then the same thing the shop said...
but get you a new one, and rebuilt the one you have, its not that hard, you can do it... as long as your mech inclinded...
Old Mar 20, 2010 | 04:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You sure it's not the Cardan joint on the front driveshaft? Or is the noise there when not moving?
Old Mar 20, 2010 | 09:24 PM
mnewbolds's Avatar
mnewbolds
I know it's not the joint in the d-shaft. It'll squeel when not moving. Just today I engaged it to see if a neighbor could see something I hadn't. OF COURSE it doesn't make a sound. WTF...
But as for meanwhite, Yeah, it's all stock. Just the 5.2. No lockers....yet.
Anyone know a good source for a t-case? I found them at RockAuto and few others but I would like to use something a little more reputable. Thanks
Old Mar 20, 2010 | 09:41 PM
dhvaughan's Avatar
dhvaughan
$600 here rebuilt.
scroll down in the little center window to dodge.
http://www.transfercases.com/order.htm
