Bent rim or bad wheelbearing, again...
Old Mar 20, 2010 | 01:45 PM
yakkier's Avatar
yakkier
Default Bent rim or bad wheelbearing, again...
Man what the hell, i just replaced the passenger side and now the driver side is acting up.
At very low speeds i can kinda stick my head out the window and watch my wheel wobble, it doesnt do it alot and it almost looks like a bent rim but it sqeeks like a bad wheelbearing. I already checked that side and it was tight no play at all.
Also im finding i have a clicking coming from the right rear tire some im hoping my rearend isnt going out.
Old Mar 20, 2010 | 08:55 PM
omegax's Avatar
omegax
That sucks, for some reason in my trcuk the wheel bearing went, wheel almost fell off, so every time i service it i always check em and do find the nut holding them in needs to be tightened from time to time.
Old Mar 20, 2010 | 09:01 PM
yakkier's Avatar
yakkier
i had checked the driverside when i took the rim off to bleed the breaks, it was tight and straight. So im wondering that maybe either the rim is bent and possibly hitting the break shield and that might be the sqeeking im hearing. Im taking tomorrow off so i'll pop the damn rim off again and check it
Old Mar 20, 2010 | 09:16 PM
95RAM360's Avatar
95RAM360
hey Yak remember what i said.....i had a hop when turning left, checked my drivers wheel bearing...it was tight, but then when i changed it, i found it was actually bad,so i warenteed the one i did on the pass. side, so i had 2 new wheel bearings going in at the same time.
Old Mar 20, 2010 | 09:28 PM
yakkier's Avatar
yakkier
Gotcha! i remember now.
Old Mar 20, 2010 | 11:12 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
damn bud your just not having luck with that front end....well look at it this way, by time you get everything straightened out, the whole front end will be new
Old Mar 20, 2010 | 11:37 PM
yakkier's Avatar
yakkier
By the time i get it all straightend out i'll be owning a GMC......
SYKE!!!!!!!!!!!!!!!!!!!!! lol yea after the begining of the month when the bills are paid up im going to dump a few more hundreds of dollars into the damn thing..
