Freeze plug
Hey guys I'm new here and I have been looking around and I see there are some knowledgeable ppl on here so heres my problem. I have a 97 Ram 1500 with a 360 in it, the freeze plug on the passenger side is leaking it is the one under the motor mount! I am pretty knowledgeable with vehicles myself but have never had to replace a freeze plug. So I'm just asking for a little help here on what is the best and fastest way to do it correctly I have the new freeze plug its brass. Thanks
Hey, I have the exact same problem, only on the driver's side. I was wondering if you have fixed yours yet and if you had to support the engine while you removed that engine mount to change the freeze plug? Thanks for any feedback or instructions that you have.
When I replaced my freeze plugs, I got a metal punch and knocked the top inwards. That cause's the bottom to pop out. Then get some pressure pliers and pull it out. To install the new freeze plug, just use a socket that fits on the inside of the plug and hit it in. Make sure you drive it as straight as possible.
if you remove the engine mount then you do need to support the engine. you can put a 2x8 (or similar) block of wood under the oil pan (to protect it) and then a jack. jack up on the engine a smidgen and remove the mount.
I havent done it yet I plan to this weekend I suggest using a jack and if by any chance you have a engine hoist I would use that. I will never put a block under oil pan that would just be my luck that the motor would fall and crush the pan in I suggest if you dont have a engine hoist jack the motor up then stick a 2x4 or something on the side of the block against the frame and slowly let the jack down but be sure to keep a little pressure on the motor with your jack just for safe keeping.maybe a little time consumming its amazing how a 62 cent part is going to be a big pain in the *** lol if I get mine done before you do ill lead you thru it on how I done it and what not to do lol
