is my trans pooched
Old Mar 20, 2010 | 09:31 PM
PacMan360's Avatar
PacMan360
Default is my trans pooched
First off any help would be appreciated, ok i got a 99 ram 5.9 2500 with 211 000km and i am having trans problems, at first i had a huntin problem between 1900 and 2200 rpm and then i had a shifting problem where i couldn't put it into second through the colum and when hammering down on the throttle trans would shift into first skipping second entirly also when accellerating hard trans won't shift up. so i went out and bought new govenor pressure sensor and solenoid replaced filter torqued up added trans fluid. second i adjusted the kick down band as per hanes manual procedure then i adjusted tv cable now that being said the hunting is gone but trans still won't shift up out of kick down only shifts when letting off the gas then it shifts anyone have this problem before?
