Idle issue
Old Mar 22, 2010 | 12:02 PM
AdamR88's Avatar
AdamR88
Default Idle issue
My 94 Ram 1500 is idling really low at normal temp. It is a manual tranny and seems to run fine when driving. However, when I slow down or hold the clutch in while moving, the rpms drop to 0 and the vehicle stalls on most occasions. Can anyone help me with this issue? I can not figure out how to change the idle speed. I suspect that spark plugs would be the issue. I have pulled a few out and they seem fine but will probably replace them all anyway. It seems to be getting enough fuel...so i am thinking electrical.
Old Mar 22, 2010 | 06:08 PM
Aubrey's Avatar
Aubrey
Could be a bad cat. It is stalling out when it is not under load.
Old Mar 22, 2010 | 06:24 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to the forum.
You cannot change the idle speed, the IAC sensor and PCM control the idle. The IAC is a relatively cheap replacement, if you want to try that fix before moving onto more expensive possibilities. They have been known to go faulty on occasion.
