So Here Is My Problem...
Old Mar 24, 2010 | 01:27 PM
clipper77's Avatar
clipper77
Default So Here Is My Problem...
2 weeks ago, my truck had a nasty squeal coming from the belt drive. I replaced the belt and it completely stopped for about a week. A few days ago, I have been hearing a high pitch squeak again while driving. It only squeaks while driving and is worse when I let off the gas and just coast. I can start the truck up and let it idle in park with no abnormal noises what so ever. I re-adjusted the belt on the pulleys and sprayed a little bit of silicone for lube. The noise is still there. I initially thought it was a bad pulley but wouldn't it be squeaking all the time, not just while I am driving? My only other thoughts are it could be a bad wheel bearing or a bad u-joint. Thanks in advance.
Dan
Old Mar 24, 2010 | 01:29 PM
PurplDodge's Avatar
PurplDodge
Your tires? You do have a 2WD V10!!!
Take your Idler pulley off and grease it.
Old Mar 24, 2010 | 01:32 PM
clipper77's Avatar
clipper77
Idler pulley is brand new. Yes, it is a 2WD and the tires hum every time I drive.
Old Mar 25, 2010 | 11:33 PM
clipper77's Avatar
clipper77
Greased my idler pulley and belt tensioner pulley this morning, squeak is still there. When I had the tensioner pulley off, the bearing was hard to turn. I checked the belt when it was running and there seemed to be a little play in the tensioner- the pulley was moving up and down. Could I use a tensioner off of a 5.9 gas/cummins?
Old Mar 25, 2010 | 11:45 PM
PurplDodge's Avatar
PurplDodge
Probably not. Lemme check the P/Ns.
Nope, different. But same prices. Around $58 for a Gates.
Old Mar 25, 2010 | 11:52 PM
clipper77's Avatar
clipper77
Alright, cool, thanks anyways.
Old Mar 25, 2010 | 11:59 PM
95_318SLT's Avatar
95_318SLT
Are you sure its coming from around the engine? Sounds to me like a pinion bearing or something along those lines.
PurplDodge's Avatar
PurplDodge
Ah, it was nothing!
Old Mar 26, 2010 | 12:51 AM
clipper77's Avatar
clipper77
Yeah, when I pull on the throttle cable, I can hear it coming from the tensioner. A pinion bearing is in the diff, correct?
Old Mar 26, 2010 | 01:05 AM
PurplDodge's Avatar
PurplDodge
Yeah, thats what he is taking about.
Sounds like a definate engine problem.
