Transmission/ Oxygen sensor Help!!!!
Old Mar 24, 2010 | 07:19 PM
Ram4x4r's Avatar
Ram4x4r
Question Transmission/ Oxygen sensor Help!!!!
Well, I have a 2001 Dodge Ram 1500 and I just had my transmission rebuilt. Now im having an eletrical issue with the oxygen sensor. I replaced the sensor with an aftermarket sensor and when the oxygen sensor is plugged in, it causes the truck when at a stop thinking that it is still going and when the oxygen sensor is not plugged in everything is running fine.
I dont know what to do or what the problem is?
Old Mar 24, 2010 | 08:15 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
i can tell you that running 4.10 gears with 37's will cause that new tranny of yours to take a premature sh*t.....as far as the o2 sensor......get another one
Old Mar 24, 2010 | 09:42 PM
Ram4x4r's Avatar
Ram4x4r
yeah i know i need bigger gears, but my tranny went. so i had to get it rebuilt. came with a 2yr, 24,000 mile warranty. And the oxygen sensor is new.
Old Mar 24, 2010 | 09:50 PM
timwag2001's Avatar
timwag2001
is it possible that you got some crap in the wire harness, maybe some rust. try a little dielectric grease.
trace the wires, maybe they damaged it when they were working on your tranny
Old Mar 24, 2010 | 10:08 PM
Ram4x4r's Avatar
Ram4x4r
well its still in the tranny shop and they are trying to see if they can fix it but if not they are going to refer me to another shop that they partner with. They called me and informed me about this situation so i wanted to see what you guys thought.
Would it have something to do with a clogged cat? because if they are not able to fix the problem, they said that they would only release it to me with the oxygen sensor not plugged in because it would not cause a problem.
Old Mar 24, 2010 | 10:19 PM
PurplDodge's Avatar
PurplDodge
What kind of sensor did you use? Bosch sensors usually cause problems.
Old Mar 24, 2010 | 10:22 PM
Ram4x4r's Avatar
Ram4x4r
i have no idea. they didnt tell me what brand that they used.
Old Mar 24, 2010 | 10:41 PM
jasonw's Avatar
jasonw
Site Moderator
I tend to agree, but others have used them without ill effects.
I prefer NTK (made by NGK) myself.
Old Mar 24, 2010 | 10:49 PM
jamesnb's Avatar
jamesnb
What problems do Bosch sensors cause?
Old Mar 24, 2010 | 10:55 PM
jasonw's Avatar
jasonw
Site Moderator
They don't necessarily "cause" problems from what I've read, but they just seem to fail more often and not last as long.
Granted, thats not personal experience, that is just from what I've read. Take it with a grain of salt.
