VAC LINES and EGR~~
Old Mar 27, 2010 | 02:26 AM
tinkerinman's Avatar
tinkerinman
Default VAC LINES and EGR~~
Anyone have a picture or know how the VAC LINES and the EGR VALVE hook up??
The EGR is obviously mounted to the intake...
But there is also an electical VAC side to it...
Everything on the drivers side is good. I just dont think it was Ever hooked up right... Used to get a code for it every once in awhile...
Yesterday---
I pulled the intake manifold and TB to swap the plenum...
Vatted the intake and TB... (cleaned them)
Today---
Installed new aluminum plenum plate and gasket...
Replaced the thermostat and gasket as well as... upper and lower radiator hoses...
Change oil pressure switch oil and filter...
Replaced EGR Valve gasket...
Replaced Alternator...
Basically all should be working fine again... Im just not sure about the VAC LINES>>>>
Old Mar 27, 2010 | 04:34 AM
95RAM360's Avatar
95RAM360
its pitch black out right now, (430 am) and i have to work today, but if no one has replied, ill post some pics of what mine looks like tonight....do you have a haynes manual? If not, it would be a good time to purchase one
