Strange starting and surge idling
Old Apr 1, 2010 | 03:50 PM
  #21
Activate's Avatar
Activate
I replaced both...no effect....
Thanks and greetings,
Erik.
Old Apr 21, 2010 | 01:06 PM
  #22
03neonSE's Avatar
03neonSE
This may be a stupid question but have you checked your intake bolts? On mine, I found out that all but 2 were not down to specs.
Old Apr 21, 2010 | 01:20 PM
  #23
pcfixerpro's Avatar
pcfixerpro
How about reseting the computer a while if you haven't already done so. Pull the neg cable, go in and turn the key to start your truck and hold it for a few sec. Hook the cable back up. Re-plug in your sensors if disconnected, Put the throttle plates back in regular position. When it starts it should high idle and slowly work down the idle. That should be a good test to double check that the IAC is functioning properly.
EDIT... nvm, you just said above you swaped the battery out. This would have taken care of the above.
