Trying to clarify where the RTV sealant goes at the plenum
Old Mar 29, 2010 | 09:16 AM
Jacksoncove's Avatar
Jacksoncove
Question Trying to clarify where the RTV sealant goes at the plenum
Hi all
I am in the process of installing the Hughes plenum repair kit, I have a question regarding what type of RTV sealant? and where do I put it it says at the corners? any help would be great
Thanks in advance
Old Mar 29, 2010 | 09:38 AM
Silver_Dodge's Avatar
Silver_Dodge
A bead goes along the front and rear gaskets that go on the block (the rubber ones), and then put a good amount in the corners where the intake manifold meets the heads.
Old Mar 29, 2010 | 09:44 AM
Sheriff420's Avatar
Sheriff420
I thought it just went on each end of the intake end seals where they contact the heads. That's where I put it and it isn't leaking.
Ultra black works just fine.
Old Mar 29, 2010 | 10:10 AM
Jacksoncove
Thanks Silver Dodge and Sherrif I guess if they both work it does not matter, But I like the idea of putting a bead along the whole surface, do I apply it to the underside of the front and rear gasket where it meets the block or do I apply on the block first? I assume just a thin coat? also how clean does the mounting surfaces block and intake have to be? I used a sharp razor blade on both and then wiped both of them with a rag and acetone, but you can still see the black and grey from the old gasket it is like it is impregmented on them both also the both look a little pitted as well. Thanks in advance
Old Mar 29, 2010 | 02:41 PM
RM_Indy's Avatar
RM_Indy
I didnt bother with the rubber pieces front n rear this time on mine. Just a generous bead of RTV only. Last couple 408s my buddy built he didnt use the rubber & it sealed just fine with the RTV so I thought Id try as well. I gave the final torque the following day to allow the RTV to set up.
Old Mar 29, 2010 | 03:05 PM
dodgeram07's Avatar
dodgeram07
Old Mar 29, 2010 | 05:25 PM
PurplDodge's Avatar
PurplDodge
For the plenum it depends on what gasket you are using. For the metal gasket, DO NOT use any sealant on it. Some people run the FEL-Pro gasket and put a little Utra Black or Ultra Copper on it.
I just put a little RTV on the backside of the intake gaskets (the ones on the head) to help hold them in while I put the manifold back in. I put a little bead along the end gaskets.
Old Mar 29, 2010 | 07:32 PM
dhvaughan's Avatar
dhvaughan
i put a thin coat on both sides of the front/rear rubber gaskets to hold them in place, and a generous dab at the corners.
Old Mar 29, 2010 | 07:38 PM
95RAM360's Avatar
95RAM360
ditto
Old Mar 29, 2010 | 09:36 PM
yakkier's Avatar
yakkier
God that engine is oozing perfection..... i love it!
