oil pressure problemS . . help!! anybody??
Old Apr 1, 2010 | 12:57 AM
cntryboy2500's Avatar
cntryboy2500
Default oil pressure problemS . . help!! anybody??
i have a 99 ram v10 with a 97 v10 motor in it. says 7 qts of 10w30 so i put it in an the dipstick has no oil on it at all . . ADDED another quart an its half way up to "add" should i keep adding?? like whats happening why is this happening i cant figure it out let it sit idling then checked let cool for a few hours an checked it again . . any suggestions??
Old Apr 1, 2010 | 12:59 AM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
do you have the right dipstick for it ? as long as your oil pressure is fine i would just add till it says full. make sure your on level ground
Old Apr 1, 2010 | 07:29 AM
95RAM360's Avatar
95RAM360
after you start it, you have to shut it down, and let the oil settle for about 10 minutes. you wont get a good reading if the motor had been running recently. Best time to check it is before you start it in the morning. So it had all night to settle...then you'll get a very accurate reading.
Old Apr 1, 2010 | 11:09 PM
VEETEN's Avatar
VEETEN
my 01 is 7 quarts on the nose.
Do you have a deeper pan or like the others said wrong stick?
EDIT
I should ask What is the oil pressure problem in the title?
Old Apr 2, 2010 | 02:17 PM
cntryboy2500
I did a motor swap used the dipstick from my 99 the
motor is a 97 both v10s 8.0l I was thinkin maybe shortter dipstick until the pressure gauge starting goin down to zero then up an down every few seconds I'm
up to 9 qts now
