caster adjustment
Old Apr 5, 2010 | 10:51 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
Default caster adjustment
hey guys i need a DIY link for a front caster adjustment. (death wobble)
Old Apr 6, 2010 | 10:01 AM
xxxcowxboyxxx
how about just an explanation
Old Apr 6, 2010 | 10:18 AM
charlie1935's Avatar
charlie1935
There has been discussions on this in the past, some got pretty heated.
Best I can do is to suggest using the search at the top.
Old Apr 6, 2010 | 10:25 AM
xxxcowxboyxxx
yeah i have searched pretty heavy on the death wobble subject and all has led to pinion angle from caster but i cant find hardly anythin on how to adjust it as a "quick" fix till i can get her lined up.
Old Apr 6, 2010 | 10:27 AM
sungod's Avatar
sungod
I assume your 7" lift replaced the control arms. Are your new control arms adjustable? Rotating the axle isn't the best way of adjusting caster, but it . You could also go with adjustable ball joints, but your adjustments are limited. The only real way to adjust caster on a solid axle is with a torch.
Old Apr 6, 2010 | 10:40 AM
xxxcowxboyxxx
sungod i think you are confused with camber, i need to roteate my axle like a motorcycle throttle grip and get my pinion angle up (rear of pumpkin) and no i do not have adjustable control arms
Old Apr 6, 2010 | 10:33 PM
xxxcowxboyxxx
bump bump ........ any suggestions at all ? figured someone woud have something for me. at least call me crazy or dumb or somethin guys lol
Old Apr 6, 2010 | 10:47 PM
dodgeramit_10's Avatar
dodgeramit_10
ur crazy..... i wouldnt go with with dumb but you got more ***** then i do cuz i wouldnt be driving my truck lol even though its my daily driver
Old Apr 6, 2010 | 11:34 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Get an index ring to fix the drive shaft angel.
Old Apr 6, 2010 | 11:49 PM
yakkier's Avatar
yakkier
try pavementsucks and see what they got to say.
