MonteC's Transmission Corner (For Info Only)
Old Sep 13, 2010 | 06:19 PM
  #711
David Havens's Avatar
David Havens
I have a 99 dodge 1500 and the trans went out . i also have a 96 3500 passenger van and would like to know if the trans will fit in my P.U.
Any help greatly appreciated.God bless
Old Sep 13, 2010 | 07:28 PM
  #712
MonteC's Avatar
MonteC
Originally Posted by Joey Buentello
By any chance could you tell me where I could find one?
Wittrans.com
Old Sep 13, 2010 | 07:32 PM
  #713
MonteC's Avatar
MonteC
Originally Posted by paxonedge
Hey all new here and need some help.
Have a 94, 2WD, 318 just plain jane, not sure the tranny number. I bought the truck real cheap to get stuff for the house with. I was driving on the highway when i noticed that i was running too high of RPMS for the speed i was going, not redlining just higher than normal. Shifted into neutral then back to drive, and everything was fine. Next day same thing happened tried to shift and it did nothing stayed stuck in 2nd gear. Long story short was driving it on a quick errand and now the thing wont come out of 1st. I changed the filter/fluid and it appeared to be ok, not burnt or any strange color. The guy i bought it from had replaced the the TPS, and i get the feeling he wasnt a mechanical genius after i changed the plugs and they werent gapped at all. The truck is also stalling when i put it into reverse, and now when i try to drive in gear. Could the TPS be the cause of all my troubles or is there something deeper? I took it to my mechanic and he was overwhelmed and just said to replace the tranny, but i've had no slips/grinds or anything and i dont think the whole tranny needs replaced. Thanks for any help possible.
If its a 94 then it has a hydraulic governor. The tps has nothing to do with shifting 123. The tps only has a role in 4th gear and lock up.
If the trans is not up shifting properly you could have a sticky governor, bad valve body, or mis adjusted tv cable.
Might adjust the cable and try a bottle of red smart blend.
Old Sep 13, 2010 | 07:33 PM
  #714
MonteC's Avatar
MonteC
Originally Posted by redneck_ram
have a question. cant seem to find an asnwer. i just replaced my transmission in my '01 1500 4x4. it drives absolutely beautifully, but it doesnt shift into overdrive. what kind of problem am i looking at? is it something simple? any help is appreciated.
What do you mean you replaced the transmission? Need more details.
Old Sep 13, 2010 | 07:34 PM
  #715
MonteC's Avatar
MonteC
Originally Posted by Annihilator_X9
This is where it's dripping from. Is this the inspection cover?
Could be the front seal, pump oring, pump bolts or the vent. In a rare case the converter it self could be leaking.
Old Sep 13, 2010 | 07:35 PM
  #716
MonteC's Avatar
MonteC
Originally Posted by qspinnyj
Hi i recently had my 46re rebuilt and immediately after installing it i had a problem with stalling in reverse and sticking in 2nd gear. I tried adjusting tv to both extremes and everywhere in between finally settling on the best adjustment still occasionally sticking in second gear. I have only put 3000 miles on this rebuilt trans and yesterday had to fight to get it out of 2nd into drive just to make it home. this morning ran down to the store before working on it and now it refuses to shift outta first and when i seems like it shifted into second it just revs. blew code p1756 but i think that was from high revs in 1st gear. please help if you can!
Take it back to the shop. Something is not right.
Old Sep 13, 2010 | 07:36 PM
  #717
MonteC's Avatar
MonteC
Depends on what motor is in the van.
Old Sep 13, 2010 | 08:06 PM
  #718
redneck_ram's Avatar
redneck_ram
my tranny went. i bought a rebuilt one with 10k miles on it from a 98 1500 4x4. everything shifts smoothly but over drive. it doesnt go in. from what ive researched today there are 2 types of torque converters. locking and non locking. locking has 23 splines and non locking has 24 splines. could this be the problem or am i looking at something easier as a simple solenoid?
Old Sep 14, 2010 | 01:26 AM
  #719
qspinnyj's Avatar
qspinnyj
Default thanks
thanks MonteC and HEYYOU just needed to hear that from someone else then my local friends
Old Sep 15, 2010 | 05:21 PM
  #720
Joey Buentello's Avatar
Joey Buentello
Default thanks
Wittrans.com
I found a top hat grommet that fit my trans dipstick tube in the help section at Autozone.
