How do I tell what trans I have?
Other than contacting dodge, how do I tell? The sticker in the glove box just say it's a 4 speed auto. It's an 01 1500 with the 5.2L V8, 2 wheel drive.
46re.
yep..
Wow that was fast, thanks guys.
Alot of information about your vehicle can be obtained from build sheet.
Call parts dept at Dodge dealer give them your vin number and they can print it off for you free. Dave |
98
I have a 98 with the 5.9 is it the same transmission and i am taking this truck apart to rebuild the trans, is it true a shift kit will stop it from burning up all the time and if so where should i shop for a shift kit and rebuild kit.
All V8s have the 46RH/RE tranny. 1995 was the last year of the RH trannies, every one since has been a RE.
94-96- 46RH (Auto)
96.5-2001- 46RE (auto) NV3500- Manual Transmission in v6's and 1500 5.2's NV4500- Manual Transmission in Deisels. |
Originally Posted by mean318
(Post 2081009)
No that is false. A good rebuild will make the trans not burn up all the time. A shift kit will help improve shift feel and give it more durability. But there is no shift kit in the world that can fix a bad rebuild. |
Originally Posted by 95RAM360
(Post 2081278)
94-96- 46RH (Auto)
96.5-2001- 46RE (auto) NV3500- Manual Transmission in v6's and 1500 5.2's NV4500- Manual Transmission in Deisels. This was verified when I replaced transmission last November, the governor is electronically controlled. Dave |
