Transfer case problems
Old Apr 8, 2010 | 03:18 AM
97tn4x4's Avatar
97tn4x4
The front half on my 97 case was cracked. I had a guy tear it apart and tig weld the crack. I then jb welded inside and outside the case and it still leaks around the detent bolt(which has also been siliconed). That's why I didn't just change the plug. I need the guts from my old case in the new case. How hard would it be to switch? Did 4wd light stop working because of the difference in the cases? I even changed the switch out with mine.
Old Apr 8, 2010 | 07:53 AM
97tn4x4's Avatar
97tn4x4
Well when I got home from work this morning I tried putting it in 4wd to see if the light came on and now it does so I think I'm gonna leave it in for awhile. But how come my speedometer isn't working?
Old Apr 8, 2010 | 09:23 AM
95RAM360's Avatar
95RAM360
is the brake and abs light on as well? if so replace the speed sensor
Old Apr 8, 2010 | 10:02 PM
97tn4x4's Avatar
97tn4x4
No there not on. It worked before switching the cases out.
Old Apr 8, 2010 | 10:40 PM
97tn4x4's Avatar
97tn4x4
Old Aug 2, 2010 | 05:38 PM
litterfisher's Avatar
litterfisher
I've gone through 2 Transfer Cases on this thing and its a pain to find non destroyed used ones
