Upper Control Arm Bushings 2wd 1500
Old Apr 8, 2010 | 09:58 PM
heybuddy1901's Avatar
heybuddy1901
Default Upper Control Arm Bushings 2wd 1500
How do i get them out?
the stupid cam bolt goes through the thing so i cant get a ball joint press on it.
cut the bolt and get new ones?
the easier the better, i already have the new bushings.
Thanks in advance
Old Apr 8, 2010 | 10:14 PM
BIGRED97's Avatar
BIGRED97
you gotta remove the control arm, get them pressed out, and the new ones must be pressed in as well. its kinda a PITA to get to the control arm, but its possible.
Old Apr 8, 2010 | 10:20 PM
heybuddy1901
yeah i know, i had the control arm off.
the cam adjuster bolt goes through both bushings and cannot be removed unless one of the bushings is removed.
the piece of **** ball joint tool i rented bent halfway through the ball joints so it was useless, but there wasnt a way to get it in place anyways..
so whats the preferred method? a puller?
i dont want to cut the cam bolts as they are $50 EACH =\
Old Apr 9, 2010 | 09:51 PM
heybuddy1901
no one? =\
Old Apr 9, 2010 | 10:02 PM
BIGRED97's Avatar
BIGRED97
im sorry i didnt realize you were 2wd, i believe its different.. hopefully some will chime in, i dont have any expereince with the 2wd suspension
Old Apr 9, 2010 | 11:14 PM
xjarhead69's Avatar
xjarhead69
Originally Posted by heybuddy1901
no one? =\
According to shop manual they are not serviceable.
You can find that info on page 2-8 of the service manual that can be downloaded from faqs section of this forum.
Thats why I didnt replace them on mine when i replaced everthing on my truck last year.
Dave
Old Apr 9, 2010 | 11:22 PM
xjarhead69's Avatar
xjarhead69
If they really need to be replaced, you can buy complete control arm with bushings and ball joints installed.
You better be sitting down when you price them, I remember it being around $1000 or more for all 4.
Rock auto has them
Dave
Old Apr 9, 2010 | 11:34 PM
heybuddy1901
i read that as well, but why would autozone/rockauto
AND the dodge dealership, sell replacement bushings?
Old Apr 9, 2010 | 11:49 PM
xjarhead69's Avatar
xjarhead69
Even my Chiltons manual states their not serviceable.
Dave
Old Apr 9, 2010 | 11:55 PM
heybuddy1901
well, going to the shop on tues.
ill stick them on the press, if they come out, sweet, if not, oh well.
