1995 ram can i remove egr when i mod kegger or should i leave it
i cut the tube on each end, shoved a bolt through it and had them welded to eliminate my egr....new intake came with a block off plate, so i used that, and i left everything else hooked up....ive had a check engine light 4 times in the past 7K...but when i shut the truck off and turn it on, no more CEL...
yeah, i get a cel every great once in awhile but its wierd cuz it always comes with a torque converter code also
