Some Random Suspension Questions.
Old Apr 12, 2010 | 10:36 PM
sk8erdude's Avatar
sk8erdude
wow nvm on that one, that wouldnt work im a dumb@$$. forget that idea!!
Old Apr 12, 2010 | 10:38 PM
intense00's Avatar
intense00
Are you sure what you heard is not a leaf spring shackle flip?
Old Apr 12, 2010 | 10:42 PM
sk8erdude's Avatar
sk8erdude
no i know what that is, idk what i was thinking on flipping it
Old Apr 12, 2010 | 10:43 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
ill leave your comments alone. you made yourself look dumb without our help
Old Apr 12, 2010 | 10:44 PM
SpcD1500's Avatar
SpcD1500
i have had two 3" blocks on my truck sence september and havent had any problems with them. but i did just order brand new 5.5" fabtech leafsprings so i can ditch the blocks and hopefully get a better ride out of it
Old Apr 13, 2010 | 08:51 AM
sk8erdude's Avatar
sk8erdude
so does anyone know about using a zero rate and shims? or the exact amount of lift before drive shaft problems?
Old Apr 13, 2010 | 12:59 PM
xxxcowxboyxxx
i have 9" of lift. well only 7" of suspension, and never a problem. i had a frind with 12.5" and had no problems with the rear shaft, but front shaft would bind one in a while when his axle would drop when offroading
Old Apr 13, 2010 | 01:59 PM
sk8erdude's Avatar
sk8erdude
wow 12.5 inches? what about brakes lines/vacum lines?
Old Apr 13, 2010 | 02:11 PM
sk8erdude's Avatar
sk8erdude
another quick question, i have the 5'' skyjacker lift kit and it came with a dropped steering arm, how much lift is that arm good for? how big of a deal is it if you have more lift on a smaller arm?
Old Apr 13, 2010 | 02:29 PM
97black_ram's Avatar
97black_ram
I thought the only reason to use a zero rate block was to re-center the re-axle after a reverse shackle flip. What other purposes do they serve?
