Some Random Suspension Questions.
just wondering a few things. sorry if theyre obvious.
1. So i have 2 inch blocks in the back. If i wanted to have a 5 inch lift, would i stack a 2 and a 3 inch, or just one 5 inch. Obviously one 5 would be better, but can you stack blocks?
2. Can you use a zero-rate block and shims? Would you just have to drill new holes the shim for the holes to line up?
3.What is the maximum amount of lift you can go with before drive shaft length or u-joints become an issue?
4. Can you flip a leaf spring over to gain/loose lift? I've heard you can.
Some people stack blocks, but i wouldnt , it's kinda shady and dangerous some people havent had any probs some have.. and i thought i read the 3/4 or 1 tons had a 5 inch block to begin with from the factory so why not, most people will say get springs and ditch the blocks,
my 99 ram had 3" blocks satcked on 3" blocks for 2 years an never a problem. i have a 9" lift on my 96 and no driveshaft or u joins bind anywhere. dont flip your leaf springs over, that just sounds redic, think about it.
just think about it in you head for a minute about how leaf springs work and then flip them over and think about it......... now does it seem f*cked up ?
