Fuel pump connector voltage??
Old Apr 13, 2010 | 07:36 PM
sit22 II's Avatar
sit22 II
Default Fuel pump connector voltage??
I have no fuel pressure at the fuel rail, fuses and relay are good
so i drooped the tank and check the voltage at the connector and one of the wires has 7.5 v and the other has like 5 volts.... is this normal ??
I was thinking it was since both make 12 volts
Old Apr 13, 2010 | 10:04 PM
sit22 II's Avatar
sit22 II
Anyone??
Old Apr 14, 2010 | 03:25 AM
mrfarrell's Avatar
mrfarrell
its probly a bad ground..if that doesnt pan out double check the relay..i believe there is a ground on the frame close to where the box meets the cab..dont hold me to that good luck
