will the 20" wheels from a 07 dodge 2wd fit under a 99 2wd
Old Apr 16, 2010 | 12:29 PM
Johnboy11's Avatar
Johnboy11
Default will the 20" wheels from a 07 dodge 2wd fit under a 99 2wd
I have found a heck of a deal on some 20" factory wheels with new tires $500 for all. Since I was looking for tires anyway I thought man I love those newer 5 star wheels. Will they fit withought any modifications?
Old Apr 16, 2010 | 01:29 PM
nathangfnd's Avatar
nathangfnd
i tried putting my 20s from my 99 on my 08 but problem being it the bolt and lug nut seem to be to big on the 08.
So putting 07s on a 99 and the hole might be to big and want to wiggle loose and be unbalanced
Old Apr 16, 2010 | 02:27 PM
redheadhunter21's Avatar
redheadhunter21
Most likely you will needs spacers, not 100% sure on that though I know that chrome 04's will not fit on my truck unless I get spacers or adaptors, there are a couple people that have put newer rims on their 2wds and if you find someone who has done it ask what size spacer they used.
The lug pattern is the same so that is not the problem what you run into is a problem with the hub being too thick
They might fit without modification if they are the aluminum ones not chrome they might fit without anything....I would try and see if they fit before you buy and if it comes down to it you have decide if you want spacers
Old May 7, 2010 | 07:09 PM
ram22's Avatar
ram22
1/4"spacers dont work i tried on a 1999 2wd ram
